Showing BIM data in Arkio requires a Pro or Enterprise license. You can learn more about our paid licenses on our website and can start a free trial from Arkio to try this feature.
Arkio supports showing BIM data from exports of Revit and BIM 360/Autodesk Construction Cloud. To use this feature you can click on the BIM data tool on the top right of Arkio's 2D UI. Then press select and hover the element you would like to inquire about.
Please note: This will currently highlight all objects with that material but will show the correct parameters of the Revit instances hovered and selected in the BIM data panel
You can access this panel in VR from the expanding tab below the main menu with additional tools and settings. From The BIM data panel you can also add sticky notes to your 3D scenes to highlight issues, and clashes or just leave simple notes for others to discuss later.
