Release notes v0.7.0
Follow
New Arkio features
- New UI, navigation and modeling tools on iOS, Android and Windows (non VR)
- Modeling and drawing in augmented reality on mobile devices
- Import submenu for placing custom models and images
- Automatic backup/history of your models for the last few hours
- New Arkio props and corresponding Revit Families
- Teleport, model and sketch on all Arkio props and imported geometry
- Proportional scaling of props and imported models/images
- Highlighting of locked faces and dependencies when doing edit operations
- Gather users in a meeting around you by selecting own name in meeting panel
- Rotate Arkio prop or imported model with thumbstick/touchpad before placement
- Tutorial model accessible from Scene viewer
- PC screen spectator - 3rd person camera and collaboration with all tools
- Broadcast Arkio scene data as JSON to webserver (experimental)
- Import Arkio program data as JSON from webserver (experimental)
- Import videos into Arkio (experimental)
New Revit plugin features
- Convert Arkio shapes to native Revit masses
- Convert imported mesh geometry to Revit Families
- Convert imported materials to Revit materials
- Convert Arkio sketches to Revit families
Improvements
- Persistence improvements (please note that models created with a prior version may not load in version 0.7.0)
- Memory and performance improvements
- Improved moving and snapping of shapes
- More stability while working with stacked shapes (floors)
- OBJ Import supports larger models and more material types
- Imported models show number of polygons before placement
- Higher framerates with heavy imported 3D models
- Models up to <1,5M polygons can now be loaded on mobile devices (not more than 250K polygons recommended for Oculus Quest)
- Auto-detection of older or corrupted Arkio project files
- Unit scaling of imported assets
- Program shapes imported based on square feet or meters
- VR UI improvements - secondary menus, model carousel and material drawers
- Support for large scale models up to 20x20km
- Improved programs, settings and utilities UI
- Improved Revit plugin import UI
- Drawing on imported pictures and props
- Section placement and visibility
- Working with and modeling on imported models
- Placing models/props now happens on releasing of the trigger
- Simplified import and export folder structure on Oculus Quest
