Release notes v0.6.0
Follow
Improvements
- More reliable guide snapping for create tool
- Props can be placed reliably on different surfaces
- Export 3D model enhancements
- UI Style enhancements
- Improved layout of settings panel
- Improved keyboard layout
- Company ID for additional meeting room security
- Improved user models handling when joining a meeting
- Global undo/redo for meetings
- Better handling of prism shapes
- Update total area calculations when cutting shapes with voids
- Area exports to CSV as individual program areas instead of totals
- Limited size of sketch on plane to prevent infinite sketches
- Moving smaller object now possible in bigger loaded context models
- Area tag visibility enhancements and toggle on tablets
New features
- Teleport on imported 3D assets
- Create new shapes and horizontal sketches on top of imported 3D assets
- Scale size of worktable by pulling on its edges
- Pan map around using the pan controller in the map panel
- Cut voids through a stack of shapes
- Specify the size of an imported 2D image in meters
- Specify the units of an imported 3D model
- Automatically place imported 2D or 3D assets on the worktable and scale the worktable to fit
- Transparent material in material library (under architecture tab)
- Become the meeting master in multi user to switch to other design options
- Click on other username in multi user to teleport to their location
