Loading 2D references like drawings, pictures or sketches can be very helpful during the design process. We currently support the loading of PNG files (ideal compression format for line drawings) and JPG files (ideal compression format for images)
If you like to import floorplans or sections from your favorite CAD application we recommend exporting your drawings as higher resolution PNG so you could clearly see the linework and text while working on your plans.
The loading of Images in Arkio can be done by placing the files in
Windows
%userprofile%\Documents\Arkio\Import\Images
Quest
Quest\Internal shared storage\Android\data\com.arkio.arkio\files\Arkio\Import\Images
iOS & Android
Files\Arkio\Arkio\Arkio\Import\Images
After the start of the app (or at refresh at runtime), the images can be found under the import tab of your create-tool and can be placed manually as an object in the scene or a (non-editable) reference on the table.
Intersecting images with Arkio geometry
Images and imported models can intersect with Arkio geometry so you can use them as a design reference from your floorplans/sections. To do this you can just place the images in the scene and use the move tool (laser of grabbing the image with your hand) to position the image where you want to align it.
If you have trouble aligning it to the correct plane try to disable the snaps/guides (thumbstick down) or getting a bit closer and make yourself a bit smaller to work with more accuracy.
Known limitations:
- Thin images can sometimes be a bit harder to grab and move than solid Arkio geometry
- Recommended image file < 2Mb and not bigger than 5000 pixels
- It might take a while for other users in a multi-user session to see your images depending on your file size (progress bar shown)
