If you are experiencing issues with Arkio you can use the following paths to gather logs from Arkio to share with us by sending an email to support@arkio.is
The logs have the following file names:
Player.log
Player-prev.log
Arkiolog-COMMON ...
Windows
On Windows, the Arkio logs can be found in the following path
Mac
Mac uses a hidden system folder that you can access by searching for "Arkio" in Finder or using Finder > Go > Go to folder ~/Library
