Quest for Business
Quest for Business, makes it easier to manage a fleet of Quest headsets and deploy custom-developed applications via APK files. Official Meta Quest store applications like Arkio can also easily be deployed to all your QfB headsets using the QfB management portal.
You can add Arkio to your device library from the "Discover apps" tab
Selected store apps can be added to individual devices or as a device profile that will be distributed to all connected devices.
After this, your Quest for Business users will find the Arkio app under their apps and "For work" in their Quest app library.
ArborXR
Using ArborXR users can also add official Meta Store apps to your app library so you can still simplify app access on your fleet of Quest devices for your users. You can learn more about the steps to add apps like Arkio to your AnborXR fleet here:
https://help.arborxr.com/en/articles/6417898-unmanaged-apps
Arkio's official package name for setting this up is:
com.arkio.arkio
ManageXR
Using ManageXR you can also add official Store apps to your library. You can follow the instructions on how to do this on their website:
Other MDM solutions
Please refer to your other device fleet management documentation to see if it also supports loading official store applications from the Meta Quest Store.
Adding Arkio licenses
If you have a paid or educational Arkio license these can be assigned by filling in the license key inside the Arkio settings panel on the appropriate headsets.
Official apps vs APK files
Only official Meta Quest Store apps can access Meta-specific features like co-located Mixed Reality with shared anchors, room imports, boundaryless mode, Meta avatars, and in-app payments. These features are not available when loading custom APK files. Since Arkio requires these features and auto-updates to stay compatible with other supported devices we recommend installing Arkio from the official Meta Quest Store and cannot supply custom APK files.
