Running the same app on multiple Quest headsets using the same Meta account can result in an issue where the headsets will show a warning, “Already playing this game on a different headset” or "multiple devices can’t access this app at the same time"
This is a known issue with the Meta store using the "App sharing" feature. When "App sharing" is enabled on any of your logged-in devices, it prevents your apps from running simultaneously on other headsets logged in to the same account. You can work around this by disabling "App Sharing" from all your devices from Settings>Profiles
Disabling the app-sharing feature or removing any guest meta accounts from your headset allows Arkio and other store apps to run simultaneously on as many logged-in devices as you like.
An alternative is to use Meta for Business to manage your headsets or log in to the headsets from different Meta accounts.
If you have questions about this, please contact Meta's customer support. They should be able to help you with any account, system or appstore limitations you might be experiencing.
